Sonicstage Update Database Problem, Need Help
Keaton
Whenever I try and open sonicstage 3.1, it says 'updating sonicstage database, sonicstage will be restarted after the updating is complete' and when i hit 'ok', it says 'comverting sonicstage databases' for 1 second, then exited itself.
I have uninstalled it correctly, and renstalled it, and it still does not work, cant anyone help?
Also my sonicstage system information restore tool cannot conect to the internet
  kizzatha1 said:
I am having the same problem
SONIC STAGE 3.1 keeps attempting to update the database on starting up the program it then just exits and nothing happens. I've attached screenshots of what happens!!
both of you, try using the search function of these forums (or scan through the Software/FAQ's pages a bit)... as I'm 100% sure that this problem has been adressed (and solved) before!
give it a shot...'cause as you know, knowledge doesn't come for free
(if -after some serious searching!- you still have questions, I'm also 100% sure that someone here on MDCF will try to help you! they just don't react when the same question is posed again and again...)
good luck and greetings, Volta
Edited by The Low Volta
