Unrecognised Nh600d
de1nonly
Just downloaded and installed Sonic Stage 3.1. Prior to this i had uninstalled OpenMG Sonic stage 2.0 and all other realted progs.
The installation of 3.1 went ahead with out a glitch but now it can't see my NH600D when i attach it to the computer.
I can still see the removable drive in explorer when i put in a HI-MD but Sonic Stage is still blind. In the transfer section, the only options are to create Atrac and Mp3 cds.
Has anyone else encountered this problem and do they know how to fix this?
PS, i have also installed the personal audio driver thing as well but still no luck
Lots of people, myself included, have had this problem.
First, try reinstalling 3.1 completely. The online installer will tell you it's already installed but tell it to do it again anyway.
If that doesn't fix it, follow these instructions to completely uninstall SonicStage and clean up what Sony leaves behind (Step 3), and reinstall again.
http://forums.minidisc.org/index.php?showtopic=8071
If that doesn't work, then look in Downloads (top of page) for the MDAC repair tool and run that.
Knocking on wood doesn't hurt either.
I had this problem when I did a clean install of Sonicstage (after a reformat). I have a limited internet connection (read 28.8kbps, thanks to a dogey telco) so I downloaded the "allin one installer". It installed great but when I connected the minidisc I could see it in explorer but not in sonicstage. I also tried the PA driver, and it didn't change a thing.
I relented and did the online download of it (started instal, went out came home and it was done), and it worked then. My computer is set to Australian language rather than US, so I dont know if that was the problem but try an online download if you haven't done that maybe give it a go.
I just uninstalled all of the programs (go down the Add and Remove Programs) that I thought were connected to remove them, I didn't fiddle any registry entries.
Edited by roguefan99
