Audacity Help
noknees
I would appreciate help in getting tracks from Sonic Stage 3.1 into Audacity so that i can edit them. When I open Audacity and go to the Project Menu and then click Import Audio or Import Raw Data.......under the sonic stage option....I just get a list of what looks like basic program files.......I don't recognize my own recordings which i have named in Sonic Stage before importing........I must be looking in the wrong place in Audacity? I tried the Help menu with Audacity but it didn't seem to answer the question........
You can only open Audacity project files, wav, AIFF, AU, MP3, and Ogg vorbis audio files. You cannot import from Sonic Stage unless you have the original mp3 or wav file( or other supported format). Make sure you know where you saved the files and navigate to them using the import audio menu.
You can record realtime into Audacity using a cable plugged into the headphone or line out on your MD and the other end into your computer sound card line in. Then setting Audacity to record from your computer line in.
Edited by KrazyIvan
if you intend to edit your own recordings, just upload them to SS and save them as wav (available in SS 3.x) and open them with Audacity... no problem at all
This is assuming you are using Hi-MD, though. I don't like to assume things, which is what I did in my original post. I assumed you were talking about NetMD recordings. rolleyes.gif
Edited by KrazyIvan
indeed, so to get it clear:
- if you use Hi-Md, see my previous post
- if you don't (but use Net-MD or MD, but in that last case, you wouldn't use SS) refer to Ivan's first post
greetings, Volta
