Open Mg Problems
arouve
Hello, I have a SonyMZ-S1 Mini Disc player that I use Open MG software to load it with. This was working fine until recently. Now I can upload songs onto Open MG, but here is where the problem occurs. The uploaded songs show up on the Device section of the Open MG, but don't actually transfer onto the MZ-S1, even worse any previously recorded material on the MiniDisc is now erased.
Anybody ever run into this problem before?
Thanks,
Andy
Welcome to the forums, friend. Please uninstall everything related to OpenMG and install Sonicstage 3.1 from connect.com. We no longer support OpenMG softwares here.
Hello, I took your advice to remove OpenMG then install Sonicstage 3.1, but I still have the same problem I can import CD's into the Sonicstage, and the transfer process goes as it should, however when I go to playback the songs on my MD player it will display the song information, but not play. If I open and then close the MD player the disc now shows as blank and all the previous information is gone.
Andy
Sounds more like a bad writing block to me. Can you record via the analog or digital input? If not, then the recording block is busted.
Great idea, but the same problem except when I tried a direct record from a CD it recorded for about 15 seconds then stopped.
