roseyd Posted June 1, 2005 Report Share Posted June 1, 2005 (edited) wondering if anyone could help me with some expertise about copying from my MD (mz-n510) to my laptop. i recorded onto the minidisc using another recording machine- will this have a knock on problem in transferring the files? any help would be appreciated many thanks. Edited June 1, 2005 by roseyd Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted June 1, 2005 Report Share Posted June 1, 2005 (edited) wondering if anyone could help me with some expertise about copying from my MD (mz-n510) to my laptop. i recorded onto the minidisc using another recording machine- will this have a knock on problem in transferring the files? any help would be appreciated many thanks.←You cannot transfer via USB on the N510. You will be limited to realtime recording via the line in on your laptop and the headphone out on the N510.EDIT: For specific instructions refer to this thread: http://forums.minidisc.org/index.php?showtopic=7070 Edited June 1, 2005 by KrazyIvan Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 1, 2005 Report Share Posted June 1, 2005 You cannot transfer via USB on the N510. You will be limited to realtime recording via the line in on your laptop and the headphone out on the N510.EDIT: For specific instructions refer to this thread: http://forums.minidisc.org/index.php?showtopic=7070←Ivan is right, only realtime analogue recording is possible...but look at the bright side: there won't be any copyright issues greetings,Volta Quote Link to comment Share on other sites More sharing options...
