Sonicstage Ver 3.1
Butch1979
Hi
I have downloaded sonicstage the rubbish that it is version 3.1. It installed perfectly or so it seemed and then when i click on it to get it to start working it gives the error message
Cannot locate needed files related to windows media format. Exiting sonicstage.
What a heap of junk. Never got sonicstage to work and think buying the minidisc player was the biggest mistake ive made in a while. Most costly one anyway. Still cant use the thing after 3 months.
Any ideas as to what can be done?
Hi
Welcome to MDCF!
It seems that while you attempt to install SonicStage 3.1, the Windows Media Component Setup Application did not install properly. I suspect re-installing the Windows Media Component or WMFDist.exe file will resolve your predicament. Please click here for the file.
If the problem still persist, I would suggest you read the Hi-MD/NetMD Software FAQ and post back with your system specs.
Good luck.
no.1 please read the software support faqs at the top the this subforum.
btw if you get a windows media error, don't ch think that the problem might be windows media? go install the latest version of that too.
