smilingcrow Posted June 11, 2005 Report Share Posted June 11, 2005 I want to use a HiMd recorder to keep a journal and record some interviews whilst travelling. I’m wondering what sort of microphone is good for recording speech?I want to keep the equipment as compact as possible and to that effect I’ve been looking at a couple of Sony’s:ECM-MS907 & ECM-719 They are both electret condenser mics; are they suitable for speech recording? Any other suggestions up to $150?I intend to use the mic pre-amp on the MD recorder rather than an external box. Any help appreciated as I’m not up on microphones. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 12, 2005 Report Share Posted June 12, 2005 I want to use a HiMd recorder to keep a journal and record some interviews whilst travelling. I’m wondering what sort of microphone is good for recording speech?I want to keep the equipment as compact as possible and to that effect I’ve been looking at a couple of Sony’s:ECM-MS907 & ECM-719 They are both electret condenser mics; are they suitable for speech recording? Any other suggestions up to $150?I intend to use the mic pre-amp on the MD recorder rather than an external box. Any help appreciated as I’m not up on microphones.←for speech (interviews, lectures...) I use a Sony ECM-C10 through mic -in on my NH900 and that works fine (but only for speech!). It cost me about €40 so $48 but that was already some time agogreetings, Volta Quote Link to comment Share on other sites More sharing options...
Matty Posted June 13, 2005 Report Share Posted June 13, 2005 I would highly recommend a Visivox Technologies mike. They're assembled in Canada and sell direct to the public. They're extremely high quality and very competitive in terms of price, so you'll likely end up paying less than 60 USD and will still end up with something compareable to one costing twice that.http://www.visivoxtechnologies.com/products.htmThey sometimes sell them on eBay, where they can be had cheaper. Quote Link to comment Share on other sites More sharing options...
smilingcrow Posted June 13, 2005 Author Report Share Posted June 13, 2005 Thanks,I'll check those recommendations out. Quote Link to comment Share on other sites More sharing options...
1kyle Posted June 13, 2005 Report Share Posted June 13, 2005 (edited) Thanks,I'll check those recommendations out.← ECM-719 It's very small and unobtrusive and stereo of course. There's an internal small watch type battery as well which lasts for ages and ages.I use it with the NH1 but it will work with any of the other models.Another advantage is that it has a DECENT length of cord between microphone and plug -- I don't like the type where the mike just plugs straight into the MD unit.With this one you can clip the mike anywhere ("CIA" or "FBI" style) while you are doing your recording -- trouser pocket for example --and you can just forget it.Good for music as well.Cheers-K Edited June 13, 2005 by 1kyle Quote Link to comment Share on other sites More sharing options...
