luigi.malago Posted June 22, 2005 Report Share Posted June 22, 2005 (edited) Hi, i'm having a problem with SonicStage,i have moved some tracks from MD to PC (live recording with mic) using sonicstage 2.0.then i made a backup of the data.then i installed sonicstage 3.1 on another computer and i imported all the backup.everything worked.the problem is that when i try to import new tracks from MD to PC (live recording with mic) i get an error:Si è verificato un errore nel trasferimento.Impossibile trasferire sul computer.Senza nomethe translation is:An error occured in trasfering.Impossible to transfer to the computerSenza nome <- is the name o the track.no matter which MD i use...home you can help me,thanks alotLuigi Edited June 22, 2005 by luigi.malago Quote Link to comment Share on other sites More sharing options...
luigi.malago Posted June 22, 2005 Author Report Share Posted June 22, 2005 i guess i understood the problem:the MD is a MD not Hi-MD.the recorder is a MZ-NH700 (Hi-MD compatible)i read in a thread:>>Note that you can't upload the recordings from your old minidiscs. Only recordings >>made in the new Hi-MD formats --PCM, Hi-SP and Hi-LP--can be uploaded.I checked the MD and i noticed that i used MD mode, not Hi-MD mode.Well i think i realized that i had to use Hi-MD mode..so now i cannot move the tracks since i use the wrong format???Why? What could be the difference in trafering files???I hate it! i didnt know it and i used MD mode since i was using a MD (not a MD 1 GB!).i didnt know that i could use Hi-MD format on a simple MD.....i think this is very frustating since there are many rules that are not clear in the MD handbook!please correct me if i said something wrong.is analog recording the only way i have to upload my recordings??thanks a lot, hope you can help me.Luigi Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 22, 2005 Report Share Posted June 22, 2005 please correct me if i said something wrong.nope you're rightis analog recording the only way i have to upload my recordings??yep...sorry, remember to use Hi-MD format next time,greetings, Volta Quote Link to comment Share on other sites More sharing options...
