smilesalot2u Posted July 6, 2005 Report Share Posted July 6, 2005 I wanted to ask has anyone tried attaching 2 D cell batteries to the external 3 volt connector on the RH10 or any minidisc , looking at the specs in theory I should be able to do it. Years ago I used to have a 2 D cell battery pack to my walkman so I figured I could do the same thing here. Voltage is the same just increased Mah storage capacity. But before I do it I wanted to ask the Masses their opinion is there any other things I haven't thought of. I bought the 2 D volt battery pack from radio shack also obtained the correct power interface, Iv'e confirmed the voltage is correct the next thing to do is solder them together and plug it in. I got this Idea from reading about digital cameras, theres a guy on the net that gives explicit instructions how to build a battery pack for the camera to take mor pics. If anyone is interested I can give the URL. To build the ultimate battery pack.All comments thoughts and opinons are welcomeThanks ahead of time Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 6, 2005 Report Share Posted July 6, 2005 As long as the battery [a number of cells] is the correct voltage and the connector the corret polarity, there shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted July 6, 2005 Report Share Posted July 6, 2005 (edited) What he said, don't mind me. Edited July 6, 2005 by KrazyIvan Quote Link to comment Share on other sites More sharing options...
ozpeter Posted July 6, 2005 Report Share Posted July 6, 2005 See here for an alternative approach I reported some time back - which continues to work very well indeed. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted July 6, 2005 Report Share Posted July 6, 2005 - You'll get no low battery indication- For recording the unit won't try to save the file system before the batteries run out of power (your recording will be lost)- It might try to charge the internal battery if there's one inserted, which will drain the external ones quicklyOtherwise, i don't see problems as long as you're careful with polarity and voltage.Taperssection has its own subforum dedicated to remote powering:http://taperssection.com/index.php?board=25.0 Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted July 6, 2005 Report Share Posted July 6, 2005 The other way would be to make something that attaches to the extr battery contacts that the AA cell pack uses. If you are crafty with a soldering iron and dont mind damaging the extra battery pack, solder some wires onto that & put a single D or C cell rechargable on them. Should give you all the low batt warnings etc but last loads longer. Quote Link to comment Share on other sites More sharing options...
