Broken Hi-md
t0fler
i was looking at a hi md in a pawn shop, there was a nh 600 in their going for 30 bucks with everything and that would be really awesome to pick up because it has optical and line in because its a recording hi md for 30 dollars, 30 DOLLARS Australian
unfortunatly this is because it doesn't work, you place a md inside the recorder and the recorder tries to read the disc and is unable to do so, and it just keeps clicking and clicking and trying to read the disc,
is the mindisc completely stuffed what are my options as far as igetting it fixed are concerned assuming i dont have any warranty
thanks
stephen
Get the number of your nearest official repair (I got mine via Sony) and ring them in advance with as much details as possible...Should be able to give you a rough idea of a quote or at least the min. to look at the machine.
From there you could make an informed decision.
