ponchio Posted July 9, 2005 Report Share Posted July 9, 2005 Has anyone figured out a way to digitally transfer music recorded (by my) older MD players to my newer MD players (expecially my HD's). Using Sonic Stage 3.x I can't transfer the music from disks to my "computer library" using my newer MD units - usually it goes through the motions - then says there was a tranfer problem.I have MZ-N505, MZ-RH10, MDS-JB920 and a MDS-NT1 to try transfers!I know I can do an analoge transfer - but I'd rather not create another generation copy. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 9, 2005 Report Share Posted July 9, 2005 sorry, the only digital way possible with (non-HiMD formatted) older MDiscs is to get a MD-deck with an optical out and record in realtime on PC (if you have an optical in) or HiMD...no usb transfer of older recordings/discs possible at all (not even with a himd-player)just read these two threads (1 and 2) and you're up to date on uploadinghope this clears things up,Volta Quote Link to comment Share on other sites More sharing options...
