Silvos Posted July 9, 2005 Report Share Posted July 9, 2005 (edited) Have you ever noticed that sonic stage can take anywhere from 75 to 100% cpu usage when playing OMA files?I just discovered that Media Player Classic can play OMA files at 1-5% cpu usage check it out here http://sourceforge.net/project/showfiles.p...ackage_id=84358 Edited July 9, 2005 by Silvos Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 10, 2005 Report Share Posted July 10, 2005 (edited) those are non-DRM OMAs though right?PS: does that even exist?? Edited July 10, 2005 by ROMBUSTERS Quote Link to comment Share on other sites More sharing options...
Silvos Posted July 10, 2005 Author Report Share Posted July 10, 2005 They are OMA's that were created with Sonic Stage 3.1, I have not tried any others! Quote Link to comment Share on other sites More sharing options...
zerodB Posted July 10, 2005 Report Share Posted July 10, 2005 (edited) That is because there is a DirectShow filter for OMG/OMA files.You can even playback OMG/OMA files in Windows Media Player.The playback kinda sucks tho, you don't get gapless. And you still need SS installed on your PC to get it to work in the first place. Edited July 10, 2005 by zerodB Quote Link to comment Share on other sites More sharing options...
Syrius Posted July 10, 2005 Report Share Posted July 10, 2005 ^^^But even so, does that mean that you can play those OMA files on another computer which is not the original? I mean, since SS is not active when you play them with MPC, there's no way it can check the DRM, right? Quote Link to comment Share on other sites More sharing options...
Prof.OND Posted July 10, 2005 Report Share Posted July 10, 2005 i'm afraid that won't be possible.The drm info is imbedded in the oma/omg file.I've done the test and was not able to play it on another computer. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted July 10, 2005 Report Share Posted July 10, 2005 ^^^But even so, does that mean that you can play those OMA files on another computer which is not the original? I mean, since SS is not active when you play them with MPC, there's no way it can check the DRM, right?←The DirectShow filter uses the OpenMG modules, same as SonicStage. The only tracks you can play are those already authorised in the same machine's SS library. Quote Link to comment Share on other sites More sharing options...
