Help! Recovering Tracks From Hi Md Disk
JANNO
Halo all! I have a MZ NH700 minidisk player/ recorder.
After trying to transfer tracks from my minidisk to my pc, I have managed to wipe my tracks by using the Sonicstage pc program.
Not only can I not locate the transfered tracks anywhere on my pc, but the HiMD disk is clean as well. When I connect my MD to my pc, I can see a couple of files with an HMA extention in windows explorer. Could this be of some use!
Help would be greatly appreciated!
Thanx
janno
hi janno, welcome to MDCF...
but I'm afraid it's bad news for you: up until now (that is until someone cracks Sony's codes...which won't be soon I'm afraid) there is no way of recovering data/music from HiMD formatted discs
Sony allows only one upload of your own recordings, so trying it a second time results in whiping them off the disc (not very logical I know, but it's Sony)...
Your only hope is to find them on your PC (maybe they are hidden or you can recover them with a data recovery tool) but not from the MDisc...
Before you upload recordings again, make sure you read this thread and follow the procedure explained in there... it is the safest way, if you follow the procedure exactly, you should never loose recordings again...
(BTW: try to post a question like this, which actually is 'software' or 'live recording' related, in the "Software support/FAQ's" or the "live recording" subsections of the forums)
