Gonzaloif Posted July 15, 2005 Report Share Posted July 15, 2005 Hi, just a few basic questions... just trying tolearn a little bit this minidisc world...!can anybody tell me how do the different formats workbetween the pc/hi-md?when i import a file through sonicstage... does it create inmediateley a "copy"of the file i was importing but in another format? if yes, in which format?what is name of the format in which audio files are stored on the MD (transferred through sonicstage) are those OMA files?and... is there any link or topic in this forum where i can read about this stuff? thanks.... Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 16, 2005 Report Share Posted July 16, 2005 when you import an MP3, WAV file or WMA it just registeres that file in the SonicStage library (no new files are created).MD (pre-netMD) use Atrac SPnetMD use Atrac SP, Atrac3 LP2, LP4HiMDs use Atrac3+ HiSP, HiLP, 48kbps, PCM, LP2, LP4, MP3converstion can be done on the fly and deleted afterwards or kept around to speed up transfer next time Quote Link to comment Share on other sites More sharing options...
Gonzaloif Posted July 16, 2005 Author Report Share Posted July 16, 2005 thanks....any idea if there is a post or page where to find out about the omg, oma files-.... just keep reading those words....just formats and extensions related stuff?thanks afain Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 16, 2005 Report Share Posted July 16, 2005 they just stand for OpenMG (.omg) or OpenMG Audio (.oma)they're both drm'd audio files Quote Link to comment Share on other sites More sharing options...
Chomik Posted July 18, 2005 Report Share Posted July 18, 2005 HiMDs use Atrac3+ HiSP, HiLP, 48kbps, PCM, LP2, LP4, MP3←I have got MZ-NH600 and I use SS 3.1. I have never seen an MP3 option before! Where can I find it? How does it work? What bitrates can be used? Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 18, 2005 Report Share Posted July 18, 2005 I have got MZ-NH600 and I use SS 3.1. I have never seen an MP3 option before! Where can I find it? How does it work? What bitrates can be used?←Unfortunately, direct mp3 playback is only available through the 2nd generation HiMD units (i.e. MZ-RH910, MZ-RH10). Also there are some reports that the mp3 playback quality is lacking. Search the forums a bit.. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted July 18, 2005 Report Share Posted July 18, 2005 Unfortunately, direct mp3 playback is only available through the 2nd generation HiMD units (i.e. MZ-RH910, MZ-RH10). Also there are some reports that the mp3 playback quality is lacking. Search the forums a bit..←right i guess I should have made that more clear (i did put it at the end ) only 2nd gen units can playback MP3s without having to convert them to Atrac first Quote Link to comment Share on other sites More sharing options...
