masterplan Posted July 17, 2005 Report Share Posted July 17, 2005 Ok, this is the first time ive posted so hi (and sorry if this has already been covered..i couldnt find it) problem is that when i upgraded to ss 3.1 upon starting it sort of loads but is unresponsive and doesnt do anything. I get the whole window up but no details within it and the bar with all the words like file, tools etc just flickers. I tried uninstalling and going back to 2.1 (i think) and the same happened to this version. I have rescued all my songs from my library but really do not know what to do as i can no longer use my minidisc with my computer... Does anyone have any ideas or suggestions to what i can do?? thanks in advance Quote Link to comment Share on other sites More sharing options...
masterplan Posted July 17, 2005 Author Report Share Posted July 17, 2005 ok...further info... it works sort of but it just flickers constantly. you can get an update of a button you press by moving the window but that is the only way to get any response.This is really bugging me, and I have tried the thorough uninstallation suggested and trying older versions e.t.c.At the moment my hi-md minidisc is worthless so pleasssse help me...anything i will try!anybody??? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 17, 2005 Report Share Posted July 17, 2005 Welcome to MDCF!Gathering from what you've just described, it seems that there could be a conflict with your video drivers. Nonetheless, please state your system info according to the tech support request rule and do review the following threads: 1 and 2 if you haven't done so. Quote Link to comment Share on other sites More sharing options...
masterplan Posted July 17, 2005 Author Report Share Posted July 17, 2005 ahh thankyou. i reckon it may be video driver related as i switched from an ati card to an nvidia one and come to think of it thats where it started. well i will give it a go tomorrow, and report back. thanks for the advice Quote Link to comment Share on other sites More sharing options...
atrain Posted July 18, 2005 Report Share Posted July 18, 2005 sounds to me like you're running skinned windows of somekind. disab le the visual themes. set the skin back to a windows standard Quote Link to comment Share on other sites More sharing options...
A440 Posted July 18, 2005 Report Share Posted July 18, 2005 It's probably the NVidia--there are known conflicts between some NVIdia drivers and SonicStage. Look at this thread:http://forums.minidisc.org/index.php?showt...10268&hl=NvidiaIt has the right version to use and a place to download it. Quote Link to comment Share on other sites More sharing options...
Astral SoniK Posted July 18, 2005 Report Share Posted July 18, 2005 yeah same problem happens here, it tries to update then closes off, and I do have an Nvidia Graphics Card,...so need to check that link out asap. Quote Link to comment Share on other sites More sharing options...
masterplan Posted July 18, 2005 Author Report Share Posted July 18, 2005 ok well got back from college early today so gave it all a go. First think i tried out was disabling visual themes and guess what ...it did the trick thank you loaaaaaads for helping me out cya around Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 18, 2005 Report Share Posted July 18, 2005 ok well got back from college early today so gave it all a go. First think i tried out was disabling visual themes and guess what ...it did the trick thank you loaaaaaads for helping me out cya around ←Brilliant! I'm glad all is well. Happy MD! Quote Link to comment Share on other sites More sharing options...
