roofrabbit Posted July 29, 2005 Report Share Posted July 29, 2005 I have an older Sony portable minidisc recorder, about 6 years old, that can record up to 80 minutes only.Recently I bought some Sony minidiscs at Circuit City described as "Premium Gold -- 80 min -- compatible with Hi-MD." When I insert one of these into my minidisc recorder, a loud racket is heard followed by the recorder message "Disk Error." Taking the minidisc out of the recorder, I see that the circular disk is broken cleanly from side to side into two pieces. This is repeatable for a new disk. Examining the Sony disk, the portion of the disc inside the dime-sized window on the reverse side is shaped differently. The Sony disks all have a center hole about 1/10", a larger dime-sized circular ring, and two sharp points at about 90 degrees to each other that joins the dime-sized circular ring. All other minidiscs that I have used before do not have the sharp points.To test the recorder, I found an old unopened minidisc that dates back perhaps five years. Inserting it into the recorder, it registered quickly with no unusual noise. I can also play recorded minidiscs with no problem.Has the specification of the minidisc changed recently? If so, where can I get the older-style minidiscs that don't break into when inserted in the recorder? Quote Link to comment Share on other sites More sharing options...
atrain Posted July 29, 2005 Report Share Posted July 29, 2005 that shouldn't happen contact sony's customer support & demand a refund. Quote Link to comment Share on other sites More sharing options...
D-EJ915 Posted July 30, 2005 Report Share Posted July 30, 2005 Or rather, take it to Circuit City and get a replacement, but tell Sony about it too I guess...although they won't do anything since they were probably made like 4 months ago. Quote Link to comment Share on other sites More sharing options...
