Jog shuttle controls
WannaBeJazzer
I've never had my fingers touch either of the sony's - the 900 or 910. Which jog dial set do you prefer? the circular 'jog' dial on the 900 - it doesn't actually spin in a circular motion, does it?
Do you know if you have to hold 2 buttons simultaneously to go into record mode for either unit?
...wish local stores had these to put the paws on...
Thanks very much, WBJ.
Olympia, WA
I have the NH900 so a quick explanation:
- the wheel actually spins (well, you spin it of course tongue.gif ) and is very easy to search songs and navigate menus on the recorder
- the NH900 has a slightly recessed rec-slider... it is an elongated button (silver) with a red extra button protruding in the middle; you need to press down the red part while sliding the silver part, but as it is just one button you do this with one finger in a smooth gesture
as I have never handled the RH910, I can't tell whether it's different, easier or harder to operate
