chilly water Posted August 4, 2005 Report Share Posted August 4, 2005 I've got a Sony MZ-N707It's not been used that much. But what is happening is:I record something with an external mic. The time counts up, I get levels. I can play it back and hear audio. It'll say Data Save and TOC Edit.When I take it out of the player and put it in another player, it tells me Blank Disc. When I put it back into the N707, it says Blank Disc. Where is my audio going? Is there a setting that I've screwed up, or is this thing just fried?Thanks for any and all help. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted August 4, 2005 Report Share Posted August 4, 2005 Maybe the TOC area of the disk is damaged/dirty. Did you try a different disk? Quote Link to comment Share on other sites More sharing options...
chilly water Posted August 4, 2005 Author Report Share Posted August 4, 2005 Maybe the TOC area of the disk is damaged/dirty. Did you try a different disk?←Yeah - same thing has happened with 3 different disks... Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted August 5, 2005 Report Share Posted August 5, 2005 have you tried using the other device to record and then playback on the first device (i.e. reverse order)? As it might actually be the second unit destroying your discs (seems you only have a problem when you put it into the second unit) Quote Link to comment Share on other sites More sharing options...
