mikio Posted August 4, 2005 Report Share Posted August 4, 2005 any startup tips before i go past charging the unit? my knowledge of MDs are basically none to nill. currently A440 and i are troubleshooting a volume/audio issue due to downloading SS-like appz off the net.consequently i decided to purchase a new MD with SS included. it's version 3.0 and i hope it works.it was economical and arrived in a day. any foresight to SonicStage issues would be greatly appreciated.until then it's back to removing cards from my PC. one by one until the problem is solved. not fun.mikio Quote Link to comment Share on other sites More sharing options...
atrain Posted August 5, 2005 Report Share Posted August 5, 2005 congratulations on the purchase mikio, i've been following your saga with great interest. Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted August 5, 2005 Report Share Posted August 5, 2005 You should download SonicStage ver 3.2 . Look in the download section. Congrats for your new MD. Enjoy! Quote Link to comment Share on other sites More sharing options...
mikio Posted August 5, 2005 Author Report Share Posted August 5, 2005 congratulations on the purchase mikio, i've been following your saga with great interest.←what kind of MD do you have? i hope you're learning as much as i am from A440. he/she is a great person to put so much effort into helping a novice. Quote Link to comment Share on other sites More sharing options...
mikio Posted August 5, 2005 Author Report Share Posted August 5, 2005 You should download SonicStage ver 3.2 . Look in the download section. Congrats for your new MD. Enjoy!←thanks for the download tip. is there a big difference between the two versions? Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted August 5, 2005 Report Share Posted August 5, 2005 yes, very many fixes and unlimited uploading are among a few Quote Link to comment Share on other sites More sharing options...
atrain Posted August 5, 2005 Report Share Posted August 5, 2005 what kind of MD do you have? i hope you're learning as much as i am from A440. he/she is a great person to put so much effort into helping a novice.←i've only got some mdlp players these days but i'll step back into md with a gen3 himd probably. luckily i have a highish level of computer knowledge, for me the pleasure is watching your discoveries & the charm & patience shown by a440 in helping you over such a long period. Quote Link to comment Share on other sites More sharing options...
mikio Posted August 5, 2005 Author Report Share Posted August 5, 2005 luckily i have a highish level of computer knowledge, for me the pleasure is watching your discoveries & the charm & patience shown by a440 in helping you over such a long period.you should join in. Quote Link to comment Share on other sites More sharing options...
LJM Posted August 13, 2005 Report Share Posted August 13, 2005 (edited) Well, I finally managed to get hold of a Hi-MD unit today - the RH910. I'm a bit stuck at the moment, because I haven't got any Hi-MDs for it. Anyway, it looks and feels great, and I can't wait to use it properly. I just have a couple of questions though:1. What are the magnetic clamp things for? And why have I got three of them?2. Can you only charge the unit with an MD inside it, or is the battery initially fully charged?EDIT: Well, it seems that the battery charges, but the indicator disappears when I plug it into the mains. It reappears when I remove the adapter though. Edited August 13, 2005 by LJM Quote Link to comment Share on other sites More sharing options...
LJM Posted August 13, 2005 Report Share Posted August 13, 2005 Sorry about the double post, but this is seriously confusing.Can you not charge the battery from the mains? It seems to work fine through USB, as the indicator is showing that it is charging. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted August 13, 2005 Report Share Posted August 13, 2005 1. What are the magnetic clamp things for? And why have I got three of them?←Answer to:1) those clamps are known as ferrite core - use to reduce or eliminate electrical interference. Quote Link to comment Share on other sites More sharing options...
LJM Posted August 13, 2005 Report Share Posted August 13, 2005 Aaah. Forget my other questions, I decided to use some common sense and look in the manual instead. Quote Link to comment Share on other sites More sharing options...
