SonicStage 3.2: New ATRAC3+ bit rates for RH10?
ForegoneReality
..But are the new Sonicstage 3.2 Bitrates compatible with the RH-10 or are the standard three all it can play?
I'm not fond of it's Mp3 playing capabilities; but I love the 256kb/s Atrac3+ quality. I can only imagine how good 320kb/s would sound on the RH-10 so I hope it's possible.
Also, hello.! This is my first post.
Hope you guys can help.
That was quick!
Thanks for the reply Ishiyoshi. I don't mind that restriction too much; I'm just glad that Atrac3+ is as good as I expected it to be. 256 will do nicely; especially with my recent revelation of the CDX-R6550's ability to play that bitrate.
Looking forward to adding that little unit to my car in the near future.
Can you just confirm please someone... SS 3.2 has come out in all versions now? and it is wise to upgrade? Or is it still in its trial testing, and a proper release will come out soon.
Last time there was the new SS, I received an e-mail from SS, notifying me about it. Havn't got one yet for this 1 though...
Should we uninstall the previous version of SS, before installing the new 1?? Or do we let it go over the top?
Do we need to backup songs as well? Or should it just have the same songs we had before in the pervious version? I hope I don't have to import all my songs again.. an then delete the one's I don't want! tongue.gif
You can install over the existing version 3.1 (if that is what you have); and of course, as a safeguard please backup your library before the update. If your library is not large, I would recommend that you reconvert your CDs to ATRAC3plus format without the DRM - it's better in the long run.
