RECORDING ON MY MZ r700
dieselducy
I have a mzr700 and I record with the mike.. the only prob, the recording is very clear but there is an emphasis on the low frequency sounds even in a quiet room.. is there any way to adjust the bass and treble in recording?? I just use a cheap sony mic that came with a tape recorder...
The only way to adjust bass and treble in recording is through an outboard mixer. Invest instead in a good pair of mics--your Sony probably is for recording speech and doesn't have any high end.
BMC-2's from Sound Professionals are usually $35 on Ebay and will pick up both highs and lows. Get clips for them and you can put them anywhere.
