Paula Posted August 20, 2005 Report Share Posted August 20, 2005 Hi-I've owned my MZ-NH900 for about a year now, but I really started using it this summer. For the past couple weeks I've noticed that it will occasionally go silent for 1-2 secs during playback. It happens at most maybe once every few tracks, and never in the same place. I'm not sure if it's the disc or the player. For the record, it's a HI-MD disc with about 8 or 10 CD's on it via Simple Burner using the Hi-SP setting.Any ideas?Thanks! Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 23, 2005 Report Share Posted August 23, 2005 What battery are you using? If it's the one that came with the unit, perhaps you should try a higher capacity NH-14WM. Have you tried different headphones as well? Quote Link to comment Share on other sites More sharing options...
Paula Posted August 23, 2005 Author Report Share Posted August 23, 2005 Thanks - I am indeed using the original battery, but I guess I feel like that should be sufficient. I am trying to rule out the headphones and the disc itself, but of course, now it won't replicate the problem. For the record I'm using Shure E3's that are about 4 months old. ( I LOVE them!) I see that you've visited the thread where this discussion seems to be continued, but for others' sake go to:http://forums.minidisc.org/index.php?showtopic=11420Thanks! Quote Link to comment Share on other sites More sharing options...
