gjkendall Posted August 23, 2005 Report Share Posted August 23, 2005 I am in the market for a HI-MD player.......price is not so much of an issue (at the moment)Is it really a case of the more you spend the better the unit, or am I being silly!I do not have a pc at home (at the moment, will be getting one soon) and was wondering how much I can copy to HI-MD using the standard optical connection....hopefully it'll be more than the 5 or so hours I can do at the moment on my Sony MZ-R501!I would be able to copy stuff to HI-MD from my PC at work though!As I understand it, the NZ models are the best....but I thought I would ask you guys!Thanks in advance for any help offered....GAvin Quote Link to comment Share on other sites More sharing options...
atrain Posted August 23, 2005 Report Share Posted August 23, 2005 where are you located gav? i'd take a look at the uk rh10. there's a number of decent reviews on this site, have a read then come back with any more Qs you might have Quote Link to comment Share on other sites More sharing options...
gjkendall Posted August 23, 2005 Author Report Share Posted August 23, 2005 where are you located gav? i'd take a look at the uk rh10. there's a number of decent reviews on this site, have a read then come back with any more Qs you might have←Hmmmmmm, I am tempted by that......How much would I be able to fit on using standard optical recording? Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 23, 2005 Report Share Posted August 23, 2005 Read up on Hi-MD here: http://www.sony.net/Products/Hi-MD/ Quote Link to comment Share on other sites More sharing options...
silence Posted August 23, 2005 Report Share Posted August 23, 2005 I am in the market for a HI-MD player.......price is not so much of an issue (at the moment)Is it really a case of the more you spend the better the unit, or am I being silly!I do not have a pc at home (at the moment, will be getting one soon) and was wondering how much I can copy to HI-MD using the standard optical connection....hopefully it'll be more than the 5 or so hours I can do at the moment on my Sony MZ-R501!I would be able to copy stuff to HI-MD from my PC at work though!As I understand it, the NZ models are the best....but I thought I would ask you guys!Thanks in advance for any help offered....GAvinHow long is a string?what is the best car to get? I don't mean to be rude but a certain amount of selecting criteria is necesary to make a choice. if it is listeing to music and transfering music from pc to player and back... no one does it better than the iPod. I own 3 MD players and one Ipod - the MD and Hi MD player/recorders I used them for recording purposes of live music- for all other purposes I have not found anything better than the iPod - I have mp3s - Wav and every possible music file in it and I've never had an issue or lost a file. Besides, the resale value should you want to upgrade leaves the MS/Hi MD units in the dust.My 2 cents Quote Link to comment Share on other sites More sharing options...
dyonisus Posted August 23, 2005 Report Share Posted August 23, 2005 Quote Link to comment Share on other sites More sharing options...
