f3choo Posted August 25, 2005 Report Share Posted August 25, 2005 Hi,I am using Rh-910 MD for voice recording in seminar or interview. Unfortunately I am getting heavy hiss in all the recordings .my microphone is audio-Technica AT9830 ,Specification as follow;Model: AT 9830 Element: Condenser, electretPolar Pattern: Stereo, directional Frequency Response: 100 -12,000HzSensitivity: 58dB +/-3dB, 1 kHz at 1 Pa Impedance Ω: 680Ω Cable Length:1.0m, come with 3.5mm terminated Weight: 5gram with cablePhantom: tap power from DV-camera or MD player with mic-in powerRecorder’s Setting:Record mode:Hi-SP Record level: Auto (AGC)Mic sensitive: HighI hope to ger rid of hiss during recording,I have some doubts here;1. Which one generate hiss, Recorder or Mic?2. If problem came from Mic, is it any Mic(Mono or Stereo) is good for voice recording without hiss? (The mic must be small enough to mount on glass or shirt).3. If I using Pre-amp mic with line in(Instead of Mic in), does it will eliminate the hiss during recording?Any suggestion ? Appreciate for your input. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted August 25, 2005 Report Share Posted August 25, 2005 Hiss is generally a problem if recording quiet sounds from a distance with miniature microphones.You can:-move closer to the source-use (large diaphragm) microphones with lower self noise-use a quieter preamp (makes only sense with better microphones, if at all)-use software afterwards for noise reductionhttp://forums.minidisc.org/index.php?showtopic=10744 Quote Link to comment Share on other sites More sharing options...
