Strangely Posted September 3, 2005 Report Share Posted September 3, 2005 Recently got a MZ-NH600 (not 600D) and SS 3.1... was all working fine using 80min md's in Hi-MD mode...getting about 13 albums onto one disc with the USB link. GREAT!!!Suddenly i can't get SS 3.1 to recognise the media, even when formatting via Device/Media initialise...it accesses the playeralways says: Used Space 0mbFree Space 0mbHave tried initialising on both player and in SS with no luckBought a 1Gb disc thinking maybe that would work, but no luck!!! The player still reads all the Hi-MD recorded discs fine, and records via line-in on both the 1gb disk and older 80min ones in Hi-MD mode.I can see the tracks on the older MD format disks, so i know the usb link works...just nothing is recognised with anything recorded in Hi-MD or with new formatted Hi-MD discsIf i set the trnsfer window to Net-MD it recognises the 80min disk fine and tells me i have space left, but i can't tranfer stuff across because suddenly SS doesn't like the format...Have installed 3.2, and no change...uninstalled, reinstalled...installed SS 3.2 on a different machine. doesn't change a thing!HELP!!! I have Win XP SP2, so i don't need the MS fix...did grab the PA driver, no help either.Have a 4 USB 2 hub, which it worked with...tried it with and without the hub nowAt my wits end ((( Quote Link to comment Share on other sites More sharing options...
Strangely Posted September 5, 2005 Author Report Share Posted September 5, 2005 Should also mention that i can see/ use the player as a logical drive in Windows...just unrecognisable media in Sonic Stage and MD Simple Burner Quote Link to comment Share on other sites More sharing options...
Syrius Posted September 5, 2005 Report Share Posted September 5, 2005 Have you tried another disc? Also make sure the write protection tab is closed. And that the little spike that detects the tab is in good condition. That's the only thing I can think of. Unless the player itself is bananas. Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 6, 2005 Report Share Posted September 6, 2005 Have access to another computer? It'd be worth a shot to see if it'll play nice with that..Otherwise, you may want to try reinstalling via the directions in the FAQ. Quote Link to comment Share on other sites More sharing options...
