mjw1948 Posted September 10, 2005 Report Share Posted September 10, 2005 Hello, Can anyone tell me if a RM-MC37lt, the AM/FM/TV/Weather remote standard on the 610 and 810 will work on the 520D? I had read that the AM ferrite antenna is built into the minidisc itself and not the remote, therefore this model remote would not work on the 520D. Someone else said that the AM antenna is built into the remote and it would work on any minidisc player that has a remote contoller standard.Thanks for any help.MJW Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 10, 2005 Report Share Posted September 10, 2005 mjw1948 said: Hello, Can anyone tell me if a RM-MC37lt, the AM/FM/TV/Weather remote standard on the 610 and 810 will work on the 520D? I had read that the AM ferrite antenna is built into the minidisc itself and not the remote, therefore this model remote would not work on the 520D. Someone else said that the AM antenna is built into the remote and it would work on any minidisc player that has a remote contoller standard.Thanks for any help.MJW←Welcome to MDCF!This tuner remote is only functional with NF610 and NF810 and D-FJ787; cannot work (nor fit) in the remote jacks of other units. For further details, please review MDCF's A Guide To Sony LCD Remotes. Quote Link to comment Share on other sites More sharing options...
mjw1948 Posted September 10, 2005 Author Report Share Posted September 10, 2005 Hello and thanks for the fast reply. i checked the guide and it says that the remote I'm looking at the RM-MC37LT will work with the 520D. I may take a chance. The supplied remote is the MC36 according to the guide but it does not have AM which my wife wants.Thanks Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 10, 2005 Report Share Posted September 10, 2005 mjw1948 said: Hello and thanks for the fast reply. i checked the guide and it says that the remote I'm looking at the RM-MC37LT will work with the 520D. I may take a chance. The supplied remote is the MC36 according to the guide but it does not have AM which my wife wants.Thanks←Ah yes, you are quite right. It should work then. Quote Link to comment Share on other sites More sharing options...
ethornley Posted September 10, 2005 Report Share Posted September 10, 2005 (edited) I own both the nf 610 and the NF520. The RCs are interchangeable but only the 610's RC (37) supports AM. AM using the 37 works on the 520. The RC that came with my 520 is the 34 model and does not support AM on either unit.Hope this helps. Edited September 10, 2005 by ethornley Quote Link to comment Share on other sites More sharing options...
