Alexx Posted September 21, 2005 Report Share Posted September 21, 2005 Hello- i made a post like this before but I have lost it and I can't find it again. Sorry if it's been posted. But can I use NiMH cells in the side-car thing?I read that the battery in the side car needed to be at a higher voltage than the 1.2 volt internal Quote Link to comment Share on other sites More sharing options...
greenmachine Posted September 21, 2005 Report Share Posted September 21, 2005 Sorry, some registrations, topics, posts & personal messages got lost due to a recent series of unfortunate events.Yes, you can use NiMH rechargeables in the external battery case without problems and no, the voltage does not have to be higher. I think you're confusing it with the power adaptor dc input, which indeed needs a higher voltage (3V). Quote Link to comment Share on other sites More sharing options...
Alexx Posted September 21, 2005 Author Report Share Posted September 21, 2005 Thanks - i never relised. i wondered why i needed to reregister Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted September 22, 2005 Report Share Posted September 22, 2005 Alexx, I have seen this as well in one of the manuals somewhere. I think it is $ony covering there backs incase something goes wrong. I have used Ni-MH batteries in all my MD equipment including the external case with the RH10 & R900 without problems. Quote Link to comment Share on other sites More sharing options...
imzu Posted September 22, 2005 Report Share Posted September 22, 2005 Alexx said: But can I use NiMH cells in the side-car thing?I read that the battery in the side car needed to be at a higher voltage than the 1.2 volt internalSide-car? Heh, i like that.Yes, i think it's 100% safe. I use 2500mah 1.2v Ni-MH's in mine with no issues.Where did you read otherwise? Quote Link to comment Share on other sites More sharing options...
Alexx Posted September 23, 2005 Author Report Share Posted September 23, 2005 Qwakrz said: Alexx, I have seen this as well in one of the manuals somewhere. I think it is $ony covering there backs incase something goes wrong. I have used Ni-MH batteries in all my MD equipment including the external case with the RH10 & R900 without problems.On here I think....It said something like the side car is used to charge the battery inside, which is used to power the MD player. Thus the voltage in my side car must be higher than that of the internal cell Quote Link to comment Share on other sites More sharing options...
