DrSiddons Posted September 24, 2005 Report Share Posted September 24, 2005 Good day.I've just received a MZ-EH1 (which I purchased from AudioCube). Great looking device!Is there a way I can change the display language from Kanji to English?Thanks in advance.DrSiddons Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 24, 2005 Report Share Posted September 24, 2005 Good day.I've just received a MZ-EH1 (which I purchased from AudioCube). Great looking device!Is there a way I can change the display language from Kanji to English?Thanks in advance.DrSiddonsIt's simple. Upon entering the menu (by holding the menu button on the RM-MC40ELK remote for a few seconds):1) Select: 各種設定 / Option 2) Within "Option," scroll down and select: 表示言語 / Language3) Select: 英語表示 (English Language)Which color scheme did you purchased? I have the black unit --> click here. Well, enjoy your new toy. Quote Link to comment Share on other sites More sharing options...
DrSiddons Posted September 25, 2005 Author Report Share Posted September 25, 2005 You are a wonderful person!!!!!!!The fixed worked!I got the black one. And it does look so sweet!Thanks.Dr.S Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 25, 2005 Report Share Posted September 25, 2005 You are a wonderful person!!!!!!!The fixed worked!I got the black one. And it does look so sweet!Thanks.Dr.SBrilliant! Happy MD! Quote Link to comment Share on other sites More sharing options...
Ellen Posted September 25, 2005 Report Share Posted September 25, 2005 It's simple. Upon entering the menu (by holding the menu button on the RM-MC40ELK remote for a few seconds):1) Select: 各種設定 / Option 2) Within "Option," scroll down and select: 表示言語 / Language3) Select: 英語表示 (English Language)Which color scheme did you purchased? I have the black unit --> click here. Well, enjoy your new toy. Do you perhaps know if it's the same for the EH930? It would be great to change the language setting on my player; now I have to guess what it says! Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted September 25, 2005 Report Share Posted September 25, 2005 If you find the same words you should try the same way. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 25, 2005 Report Share Posted September 25, 2005 Do you perhaps know if it's the same for the EH930? It would be great to change the language setting on my player; now I have to guess what it says!I don't have the EH930 at the moment. However, according to its operating manual there is no option to change language display to English – the choice of language display for the EH930 appears to be limited to either Chinese Character or Japanese Character display. Nonetheless, you can always try the following steps and check to see if English Language display is available:Upon entering the menu:1) Select: 各種設定 / Option 2) Within "Option," scroll down and look for 表示言語 / Language; otherwise, enter 表示方式選択 / Display System Selection3) Then if available, select: 英語表示 (English Language) Quote Link to comment Share on other sites More sharing options...
Deanage Posted September 26, 2005 Report Share Posted September 26, 2005 Does anyone know a way of doing the opposite i.e. inputting hiragana/katakana/kanji onto an MZNH-600?I tried cut & paste from MS Word...to no avail. The IME doesn't seem to want to work with SS. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 26, 2005 Report Share Posted September 26, 2005 Does anyone know a way of doing the opposite i.e. inputting hiragana/katakana/kanji onto an MZNH-600?I tried cut & paste from MS Word...to no avail. The IME doesn't seem to want to work with SS. Any help would be greatly appreciated.Ensure you have followed the instruction in this thread and a remote that supports kanji display. (Please note: only remote with the "K" suffix supports Japanese characters display) Quote Link to comment Share on other sites More sharing options...
Deanage Posted September 26, 2005 Report Share Posted September 26, 2005 Thank you for your help! Quote Link to comment Share on other sites More sharing options...
