COMPUTER SPACE CONSUMED
Nuvudah
When I transfer line in recordings @ Hi-LP to the computer in standard mode to convert the bit rate ( in this case talk radio recorded in 64k "Hi-LP" to 48k) back to the HD-MD the disk space is greatly used up 20 g after about 4 or five transfers even afer I delete the tracks from the library it is still stored in My Music file.
Question other than manually deleted these files how can U keep these tempoary transfer from consuming the hard disc space ?
GM, I do that but afterwards I still have to go to my music file & delete those file which goes in the recyle bin then go to disk clean up, wait awhile for it to do a scan then ok delete recyle item & some temp files. Is there some set up that would work simply the way you say ?
I have a question about deleting:
What happens if I import a mp3 song into SS, transfer it to my minidisc in hisp mode for example. Then I restart SS and in My Library I erase the imported track and check the "delete this file from the computer box". What will be erased , the original mp3, the converted file in optimized folder or both?
