Same Battery from SonyEricsson Z800i in HD5?
lindijones
2 answers to this question
Someone in the forum tried the W800i battery with the HD5 and it worked but if something goes wrong then Sony will not cover it under warrenty ...
:ol_arrow: hot~! battery and battery charger for HD5
thats right but they doesn´t have to know.
The w800i battery is not the same. It´s thicker and a little shorter.
The V800i/Z800i Battery is exactly the same thing. According to the formfactor.
Battery of HD5 shows 880 mAh and Battery of Z800i shows 900 mAh.
I don´t know.
Just a tip.
CU
Tom
