Jenna Posted October 20, 2005 Report Share Posted October 20, 2005 Has anyone tried using radiotime. I had gotten hooked on podcasts but I found that the radio programs I wanted were not available.This radiotime product is incredible. They have taken every radio station(and I mean every,) and their daily schedule and put in in their database. It has TV Guide like grid that you can customize. You just go to the program you want click it and it will be recorded. Or you just listen to it,with the ability to pause and rewind ANY live feed.You can also record 2 streams at once, while listening to a third. Recording can be done in many different bitrates. It allows you to schedule recordings from any PC.You get a 7 day free trial of the recording feature then it is 39 bucks a year. But you can use the guide and listen without any charges.It is really amazing for me since I love radio and most of the shows I like are on late at night. I just wake up and transfer them to my mz rh910 and I have hours of radio for work the next day. Quote Link to comment Share on other sites More sharing options...
Kaotic Posted October 21, 2005 Report Share Posted October 21, 2005 if it doesn't run on OS X, I wouldn't even bother.Has anyone tried using radiotime.so, that would be no! Quote Link to comment Share on other sites More sharing options...
