vercoquin Posted October 24, 2005 Report Share Posted October 24, 2005 i got a MZ-N10 recorderi recorded some rock gig in automatic mode because i hate to lose first one or twominutes of the gig i should spend to set the volume in manual mode.my records sound good to me, a part from the bass drum that often producesa bad noise with a quick fade-out/fade-in in the record.i did read somewhere about Auto Gain Control (speech or music) but i can't findon my machine that option ... any suggestion ?so i'm thinking to switch to manual mode, i could set it during the support groupperformance (the group playing before the gig i want to rec) but i know i've tokeep 'rec - pause' until the gig starts, or i will lose the manual setting.i need to know if too much minutes in 'rec - pause' could damage the MD machinethank you---fabio Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 24, 2005 Report Share Posted October 24, 2005 No way, the disc doesn't spin in rec-pause and the current consumption will be rather low, so it's nothing to worry about - no damage at all. Once you have set a certain value though, the MD should remember the setting and all you would have to do before eventually starting the recording is to change back to manual levels if you have stopped it previously.The 'standard' or 'for loud music' setting of the AGC is only available since the introduction of HiMD AFAIK, correct me if i'm wrong though. Manual levels are anytime preferrable anyway. AGC is just there for convenience - for lazy people who don't care about the best possible quality. Quote Link to comment Share on other sites More sharing options...
