Stachu Posted November 1, 2005 Report Share Posted November 1, 2005 HelloDoes MZ-RH10 support USB 2 or 1.1 only?I noticed it takes a long while to transfer large files from my unit so I just wonder because I heard it supports USB 2...I woul be really thanksfull for any reply Link to comment Share on other sites More sharing options...
raintheory Posted November 1, 2005 Report Share Posted November 1, 2005 HelloDoes MZ-RH10 support USB 2 or 1.1 only?I noticed it takes a long while to transfer large files from my unit so I just wonder because I heard it supports USB 2...I woul be really thanksfull for any replyCurrently there are no MD/HiMD units that support USB 2...It is also unlikely that there will be, since the speed of USB 2 is greater than the speed that it takes the HiMD unit to heat the magnification layer of the disc and write the data. That is, of course unless they decide to incorporate some sort of buffer, either internal or via SD/Flash media, to store data as the disc is writing. Link to comment Share on other sites More sharing options...
atrain Posted November 1, 2005 Report Share Posted November 1, 2005 they support USB2 in that it's backward compatible & will operate at the units full speed on either 1.1 or 2. 'supports' not 'usb2 native' Link to comment Share on other sites More sharing options...
