djrobin458 Posted November 2, 2005 Report Share Posted November 2, 2005 Hi. I'm about to purchase a Sony mz-rh10 (Hi-MD). I'll be recording with a mic (AT822) and need to get a wav file onto my PC. I hear horror stories about Sonic Stage!Questions:- Can I just transfer it via the usb cable? - Do I need the Sonic Stage software if I'll never transfer files FROM the PC TO the minidisc?- What's the difference between a pcm file and a wav file? Thanks for your help,David Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted November 2, 2005 Report Share Posted November 2, 2005 hi and welcome to MDCF David,to answer your questions:- yes- and yes, SS is needed for downloading (PC->MD) AND uploading (MD->PC)- in theory, if they are bit-by-bit perfectly transferred nothing reallyand to further ease your mind:there were lots of probs with SS, but with SS3.2 and now 3.3 the whole process is more or less safe-n-easyjust remember not to edit on the recorder prior to uploading and make sure you have either one of the two SS versions mentioned (3.2 or 3.3, just check the downloads section) as they allow multiple uploads Quote Link to comment Share on other sites More sharing options...
djrobin458 Posted November 2, 2005 Author Report Share Posted November 2, 2005 hi and welcome to MDCF David,to answer your questions:- yes- and yes, SS is needed for downloading (PC->MD) AND uploading (MD->PC)- in theory, if they are bit-by-bit perfectly transferred nothing reallyand to further ease your mind:there were lots of probs with SS, but with SS3.2 and now 3.3 the whole process is more or less safe-n-easyjust remember not to edit on the recorder prior to uploading and make sure you have either one of the two SS versions mentioned (3.2 or 3.3, just check the downloads section) as they allow multiple uploadsThank you so much for your answers. D Quote Link to comment Share on other sites More sharing options...
