a few questions about the new bitrates
Embio
hey, been playing around with SS3.3 for a couple of hours now and cant get my head around the 'new' bitrate options:
1, how do I get ATRAC3+ 352? I cant seem to find it anywhere :mellow:
2, what are the differences between the Advanced Lossless versions of the codecs and the standard versions?
3, what is the difference between 'normal' and 'high' quality settings for the same bitrate?
1. You can only convert to this bitrate, not rip it directly from CD etc. Once you have it in my Library, you can highlight track(s), right click and convert to 352k. Obviously its only worthwhile converting Wav files...
2. Not sure about this, but you get slightly smaller file sizes for the same bitrate than the 'raw' version. Only playable on the PC at this time.
3. The normal/high quality settings refers to the speed of ripping into Sonicstage. Slower=high quality will lead to fewer data conversion errors. Normal = faster ripping but potentially more errors=worse quality.
