migt Posted November 5, 2005 Report Share Posted November 5, 2005 I can't seem to find it. Is it possible or do I have to import the CD to SS, to convert it to 352kbps? Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 5, 2005 Report Share Posted November 5, 2005 Yeah, it's definitely not in Simple Burner. This is only available through Sonicstage 3.3. Quote Link to comment Share on other sites More sharing options...
migt Posted November 5, 2005 Author Report Share Posted November 5, 2005 I can't seem to import CDs to SS in 352 either. So what's the only option? ATRAC Lossless?352 looks so "after-thought-ish" to me. AAL isn't available in 352... Simple Burner doesn't support it... Can't import CDs in 352... Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted November 5, 2005 Report Share Posted November 5, 2005 if you really want A.352, just rip your CD's using Exact Audio Copy and import the wav's into SS -> transfer to MD in A.352 ...yes it is a big workaround, but perhaps you have some CD's that are worth it? Quote Link to comment Share on other sites More sharing options...
