MZ-N1 and No Disc error
sukhrajm
All,
I have had a NetMD MZ-N1 for about 2.5 years and only recently every single mini disc that worked fine now displays 'No Disc' and wont play.
I have checked the mini disc's in another player and and they play fine.
Does anyone no why this has started happening? Can my MZ-N1 be reset somehow or can the firmware be re-programmed?
Thanks
Msuk
The lense is duffed. Try taking a cotton swab, putting some nail polish remover in it, and GENTLY go over the lense. If that doesnt do anything at all, then fork out for a lense cleaning mindisc, tdk and sony make them. You can get one from www.audiocubes.com if you cant find one off a local etailer.
