rookie calls for help
What player do you have, and what version of SS do you have. If you have an old version get 3.3 and either have it convert to atrac, or if second generation, just download.
Again for a more accurate answer we need to know what you have,
Bob
Use sonicstage, any version. Presently in the market is 3.3 which can be downloaded from sony. You can also download 3.2 from this website in the download section.
After installing the software, you can convert mp3 to attrac3 and atrac3plus with a variety of bitrates
Hope this helps
