wesmontegomery Posted November 29, 2005 Report Share Posted November 29, 2005 I buy a sony MZ-R500. It Only have a line in input, I want to record with a mic. Can I do it? If I use a Active Microphone it could it be possible? Or could I damage de MD? Takx fr information Quote Link to comment Share on other sites More sharing options...
A440 Posted November 29, 2005 Report Share Posted November 29, 2005 I don't know exactly what you mean by an Active Microphone. If that's a microphone with a little battery, it's hard to say until you try it. It won't hurt the MD. The Line-in jack needs a strong signal. If you are recording loud amplified music, you might be able to get a strong enough signal by running a mic through a battery module like this http://www.microphonemadness.com/products/mmcbmminminc.htm or these:http://www.soundprofessionals.com/cgi-bin/...tegory/310/micsBut that will not be strong enough to record speech, quieter music, etc. For that you would need a preamp, for which the cheapest would probably be here:http://stores.ebay.com/CHURCH-AUDIOYou can also look at the Microphone Madness and Sound Professionals sites above. Many other preamps are so expensive that you'd be better off starting again and getting a mindisc unit with a mic-in jack. There is a built-in preamp behind the mic-in jack. Quote Link to comment Share on other sites More sharing options...
greenmachine Posted November 29, 2005 Report Share Posted November 29, 2005 Am i the only one to get javascript error messages on each and every microphone madness page? Quote Link to comment Share on other sites More sharing options...
A440 Posted November 29, 2005 Report Share Posted November 29, 2005 Am i the only one to get javascript error messages on each and every microphone madness page?Yes. javascript:emoticon('', 'smid_9')smilie Quote Link to comment Share on other sites More sharing options...
