Need to compromise...help appreciated
tcsta
I need a portable player that has excellent live recording capability, yet can also record audio in SP/legacy format via optical line input. I need standard format for my car dash unit.
Live recording: mainly vocal recordings --> stage rehearsals, a cappella group, choir. *It is not essential that this is done in standard format.
Other: recording from other sources through optical input --> mainly from PC using M-Audio Transit. *Must be in standard format.
If I understand the information correctly, 1g HI-MD players would work (NH900, NH1). Minidisco confirmed that 2g HI-MD players will not work (I really wanted that RH10). The problem is availability. Any other suggestions? Thanks for the help!
There's also the NH700 and/or NHF800. The NH1 might be stylish but has too many expensive proprietary parts. Optical recordings can be uploaded but not converted directly by the default software - SonicStage. You'll need a third party freeware application called HiMDRenderer for this job.
