schugh Posted December 2, 2005 Report Share Posted December 2, 2005 Just wondering if there is a way to not have the deck apply the filter.I wante to try and listen without it to do some comparisons between my CD player and the VC filter and then compare with the VC filter enabled.I haven't found any information that tells me this is possible, so maybe it isn't, but if someone knows please let me know as well.Thanks,-- Sanjay Quote Link to comment Share on other sites More sharing options...
MDX-400 Posted December 2, 2005 Report Share Posted December 2, 2005 Well the thing is every CD or MD player will utilise some sort of digital filter in its output stage...The thing is with the JB930, yours is variable, so you can change it. If you set it to "standard" that is probably the best match for the CD player's digital filter (i.e. it probably uses the same type of coefficient filter or something very similar). Quote Link to comment Share on other sites More sharing options...
