Modifying recording levels on the RH10
nittany_tim
I'm going to be jumping into the minidisc world for the first time and am considering getting an RH10. From what I've read, I see that recording levels can be modified. But are they fixed for a recording once recording begins, or can they be changed on the fly while recording (e.g., for fading selections in and out)?
Thanks a lot,
Tim
Yes, it has to be set to Pause-Rec first, then go into menu to select Manual rec. level. Level can then be changed while recording.
However, it seems to me that for something like fading selections in and out you would be much better off just finding the optimal setting for whatever you are recording, and leaving it alone. Trying to fade in and out on the recorder by constantly messing with the settings is not only imprecise (you will get uneven results), but you will risk botching a recording, particularly if it's something you are recording live that you won't have a second chance at.
Upload the tracks, convert to .wav and edit the tracks with fades on your computer. There are free audio editors in the Download section. Personally, I use Nero's (not free) Wave Editor utility and it works great for precisely what you are talking about. I'm certain the others do as well.
