two.tread Posted December 30, 2005 Report Share Posted December 30, 2005 i have recieved my nh600 (very happy with it!)and, the screen has a few anoying scratches on it, will i be able to use displez on the whole screen and the plastic SURROUNDING the buttons?please let me know as i want to be abel to order this off ebay soon.thanks Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted January 1, 2006 Report Share Posted January 1, 2006 Don't know for sure but I use Blue Magic plastic/chrome polish. It works fine for minor scratches. You have to be careful with the edges since it can get stuck in there. Quote Link to comment Share on other sites More sharing options...
e1ghtyf1ve Posted January 1, 2006 Report Share Posted January 1, 2006 I've tried many plastic polishes and scratch removers (MZ-RH10 ). The best so far has been Meguiar's PlastX, MG-12310. Amazing stuff, better than Displex. Remember, a little amount goes a long way. Non-toxic and contains no harsh solvents. Makes plastic look like new - just put a drop on your (clean) finger. That way you have control over where it goes.Cheers Quote Link to comment Share on other sites More sharing options...
