Super86 Posted December 30, 2005 Report Share Posted December 30, 2005 Good day!I own a MZ-NH900 and I wanted to know if it's possible to have a track under two groups (without actually transferring it twice), create multiple track programs, or play playlists of tracks, like m3u ones etc.I've searched the manual and I found nothing about it, but it surprises me that something so useful can't be done, so I've decided to ask here.Thank you very much for reading this! Any answer will be very helpful. Quote Link to comment Share on other sites More sharing options...
mercury_in_flames Posted December 30, 2005 Report Share Posted December 30, 2005 as far as i know, you can create playlists. Im pretty sure can do it on the unit, but am positive you can do it using sonic stage. Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted December 30, 2005 Report Share Posted December 30, 2005 you can create playlist in SS but if you have the same song in 2 playlist and transfer both to the minidisc, the song will be transfered twice. Quote Link to comment Share on other sites More sharing options...
Bananatree Posted December 30, 2005 Report Share Posted December 30, 2005 Just to back up Sebastian, he is correct. Sadly, there is no playlisting while using HiMD, although there is a similar feature that might be of use to you.I believe some recorders have a "bookmark" function, or saveable "Program" function which may work for you. Quote Link to comment Share on other sites More sharing options...
Super86 Posted December 30, 2005 Author Report Share Posted December 30, 2005 Yes, you're correct; this player has both the "bookmark" and the "program" functions, but as far as I know there is no way to save them, put names to the programs, or wathever; do you know if it's really possible? Quote Link to comment Share on other sites More sharing options...
