Transfer from disc
JohnM
First of all many thanks for the invaluable help found on this forum.
Today for the first time I attempted to transfer the classical music tracks on one of my MZNH 900 discs back to the computer using SonicStage 3.2. Unfortunately I was informed that as the disc had been created on another computer that this was impossible. The thing is - that the disc was created on this computer - the only one I have access to.
Any help much appreciated.
java script:emoticon(':(', 'smid_3')
John
Edited by JohnM
This **********MIGHT******* work:)
it will only work if the PC your using still has the original DRM information for the tracks you're trying to upload. Try one trac and see:
1) Get the latest version of HIMDRenderer
2) Use the "Scan HIMD" button at the bottom right of HIMDRenderer
3) Select the track you wish to upload.
4) Select A audio format to convert to, or select "OMA" if you wish to keep the original ATRAC data as an OMA file
5) Select an output filename
6) And press Go Render! If you get an error that mentions checking that the file plays in SonicStage, then its probably because the DRM information necassary to do the conversion is no more.
Many thanks. Will try.
JohnM
