papatakis Posted January 31, 2006 Report Share Posted January 31, 2006 HI EVERYONE!YESTERDAY I BOUGHT MY MZ-RH10...HAPPY? YES!ON MY IMAC G5 IT WORKS OK...(VITUAL PC 7)I HAD TO SHARE MY ITUNES FOLDER AND DO THE IMAGE CD TRICK WITH TOAST SOMETIMES..I ALSO GENERALLY HAD TO PUT LOTS OF VIRTUAL MEMORY TO THE VPC7I MADE AN EXTRA HARD DISC AND MOVED MY SONIC STAGE LIBRARY THERE.THAT WAYI CAN FORMAT THE WHOLE DISC AND EMPTY IT WHEN I WANT TO.(NOTE THAT THERE IS AN ISSUE WITH VIRTUAL HARD DISCS,NEVER EMPTIED WHATEVER YOU ERASED)ALSO TO END THIS I HAVE TO THANK THOSE GUYS FOR THE HAT TRICK...IT WORKED ON MY EUROPEAN MODEL PERFECTLY...THANX)(JUST TRY TO PUSH VOL- FOR A WHILE.THE FIRST TIME I DID IT I NEVER SAW DISTFL AND THE SECOND TIME TOO!I JUST CHANGED THE TWO LAST DIGITS OF THE CHANGING NUMBERS THING BY PRESING VOL- TO 24)ANY TRICKS TO MAKE VPC FASTER NOW?SONY AND WINDOWS....I MUST BE SICK/AND MY MAC TOO! Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted January 31, 2006 Report Share Posted January 31, 2006 good to hear you're enjoying the HiMD-ride...even with a mac but please do not use CAPS to type complete messages... it is really aanoying to read and is also understood by a lot of ppl as 'shouting' when used on boards/forums. Just use them only when really needed...but all in all, welcome to MDCF... but I'm afraid VPC will always be pretty slow compared to real windows Quote Link to comment Share on other sites More sharing options...
papatakis Posted January 31, 2006 Author Report Share Posted January 31, 2006 (edited) oh i am sorry if i caused you a head ache...(i cant believe people hear through screens!!)oh and compared to real windows...my vpc gets stuck a lot less than a real one..(GUESS WHY!) Edited January 31, 2006 by gastoneraster Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted February 1, 2006 Report Share Posted February 1, 2006 I hear you gaston ( pun intended)I'm getting a mac shortly (12" G4 p-book) myself but I am keeping my PC, as I have removed almost all "crashable" microsoft stuff and only install the most necessary apps... and to import my recordings I'd take PC over V-PC anyday Quote Link to comment Share on other sites More sharing options...
