ecm-ms907-to which input?
con spirito
i own an old mz-r700, and till now i have been recording my live concerts( mainly classical music) with a sony ecm-ms907 mic into the mic input.
just realized the input says "plug in power"
does it create any problem if i use a powered mic like this into a powered input?
can i record with this mic in the line in input?
thanx :(
I don't know if you have to use the internal battery or if it can also be powered by the recorder's 'plug-in-power' alone, but i'm pretty sure it won't cause problems if you use the battery.
You should in theory also be able to record via line-in with a powered mic, but most Sony mics are generally not too sensitive and cut a significant amount of low frequencies, so that you'll propably never overload the preamp anyway unless you recorder lacks a low sensitivity setting like the R700. In some situations mic-in will be too loud and line-in too quiet because of this absence.
