I have problem whith sonic stage please help
Pauell
i simply try to tansfer music to my hi-md,im using the 3.3 version of sonic stage and it cant convret my music to complete the transfer,i try the same thing to another computer and everything gone well please help.
My hi-md is sony mz-nh600 my pc is a p4 2,4 nothwood with 512MB ram, radeon9600xt ati graphics,maxtor 200gb hard drive and a gigabyte ga-8s648 motherboard with sis648 chipset.my os:winxpprosp2.The other computer that the ss3.3 working fine is a celeronB 2.2 with 256MB Ram,geforce 5200 graphics,maxtor 200gb hard drive and a intel motherboard with intel 845g chipset and he same os.if somebody can help me some how i would be pleased.
What are you trying to convert from, Pauell? MP3s? CD? Have you tried something from another source to see if it works instead?
Im trying to covert from mp3 and wav and i get an eror message that says to check if my music is protected or compatible and the same music in an other pc and with the same program converts with no problem.the only difrence actualy is the chipset.
  atrain said:
if the only diff. is the chipset then why not upgrade? sounds like you might be getting a usb issue rather than a software one
so you saying that i have to upgate the ss3.3 t ss3.4?
the motherboard with intel 845g is since 2001 and the motherboard with sis648 is since 2003.
does anybody know if ss is only compatible with intel chipsets?
im about to send the motherboard in the toilet and flash it!!!
