sh33p Posted January 1, 2006 Report Share Posted January 1, 2006 (edited) AFAIA, it isn't possible, and must be done with GYM. However, I was playing with Connect player and I noticed that while you're browsing the files on your device, the right-click context menu for any track has Import as a selection but is greyed out and unselectable... Does that mean some tracks CAN be imported, but none of mine can? Or is it a feature that Sony perhaps intends on implementing in future updates.I can tell you that it is not a result of a generic context-menu because right-clicking on tracks under the Library view gives a different context menu. Does anyone care to shed some light on this little quirk? Edited January 1, 2006 by sh33p Quote Link to comment Share on other sites More sharing options...
C_player Posted January 2, 2006 Report Share Posted January 2, 2006 I'm pretty sure this is the same feature as SonicStage, where only licensed (protected) Atrac files can be "brought back" from a device if they don't already exist on the PC its hooked to. Quote Link to comment Share on other sites More sharing options...
