danielbb90 Posted February 18, 2006 Report Share Posted February 18, 2006 (edited) I remember when I was running off Windows 98 included with windows There was a utility that increaced the size of removable media (Floppy discs ect...) - Its not included in Windows XPI was just wondering if this software would be usable for Hi-MD disc to increase the size and let it remain playble in a Hi-MD player...I can't remember what it was called but it was included with windows.... But you install it sepratly using the "add / remove windows component" option...Can I have your view on this! And would It work?Thanks,Danny Edited February 18, 2006 by danielbb90 Quote Link to comment Share on other sites More sharing options...
Roamer Posted February 18, 2006 Report Share Posted February 18, 2006 The standard windows Format doesn't work, so it is very likely that this will not work either. HiMD must be formatted by the unit or SonicStage to fit the DRM in a hidden portion of the HiMD. Quote Link to comment Share on other sites More sharing options...
